rough idle and misfire
175,000 MILES • 3.8L • 6 CYL • AWD • AUTOMATIC
JASON POND
when my car warms up it has a rough idle and misfire. check engine light does not come on. the misfire is worse when A/C is on. I can drive to work witch is about four miles car runs fine by the time I pull in the parking lot it has a rough idle and misfires. I have changed the plugs and check for vacuum leaks. please help, thanks.
Aug 24, 2017 at 2:10 PM
  • 55,766 POSTS
It sounds like you have low compression in one or more cylinders. Lets start with a compression test.
Here is a guide that will help you get the job done:
If you do not have a gauge you can rent one for free from the local auto parts store.
Please let us know what you find.
Cheers, Ken
Aug 25, 2017 at 6:14 AM
