Rough idle
87,000 MILES • 2.2L • TURBO • 2WD • MANUAL
BRADLEY WALKER
Hi there,
I recently bought the car listed above used. It is a diesel. The car had new injectors fitted and a service before I got it.
The car is very good except when the car starts from cold it idles very rough but once it warms up (two to three minutes) it is fine.
Can you provide any insight on this?
Thanks
Aug 11, 2018 at 6:10 AM
  • 55,710 POSTS
This sounds like an engine coolant sensor is not working right. But to be sure lets run the codes to see what comes up. Here is a guide to help us get started:
If this is a euro car the ALDL will be different.
Cheers, Ken
Aug 13, 2018 at 7:51 AM
BRADLEY WALKER
Hi Ken, I have taken the car to me local garage and they plugged in a Snap On diagnostic scanner - no fault codes came up and there are no lights on my dashboard.
There was an injector leaking badly which I have since had replaced but the car is still idling rough.
Thanks
Aug 23, 2018 at 6:29 AM
  • 55,710 POSTS
It sounds like you have a vacuum leak which will cause the issue you have described. Here is a guide that should help find it:
Cheers, Ken
Aug 23, 2018 at 1:16 PM
