1957 Rolls-Royce Silver Wraith Soft Pedal
CHAUFFEUR
1957 Rolls Royce Silver Wraith,100,000 miles.The brake pedal goes freely to within about 1 inch of the floor before resistance is felt.The brakes do work but require considerable pressure before being effective.Can the brake rod be adjusted ? how far should the pedal travel before taking effect?how does the servo work ? I have had the system checked but
no fault is apparent......what would you suggest ?your comments will be very much appreciated
vic
Mar 31, 2007 at 10:45 PM
2CARPRO JACK
  • 11,533 POSTS
There are no fluid leaks in the system? It sounds like the master cylinder might be by-passing internally. When the seal goes it will by-pass the pressure internally instead of greating pressure in the brake lines. Pedal should only travel a little bit (1 or 2 inches ) before the car begins to stop. If the rod wasnt removed, adjusting it probably wont help
Apr 1, 2007 at 12:57 AM
Suggested Repair
Check for external fluid leaks, then inspect the master cylinder for an internal seal bypass that fails to build line pressure. Pedal travel should be only about 1–2 inches before the car begins to stop. Adjusting the brake rod is unlikely to help if it was not removed; repair or replace the master cylinder if the seal is bypassing.
Conversation Summary
The owner of a 1957 Rolls-Royce Silver Wraith reports the brake pedal travels freely to about one inch from the floor before resistance, and the brakes need heavy pressure to work. The system was checked with no apparent fault. The expert asks about fluid leaks and suspects an internal master cylinder seal bypass. Normal pedal travel should be only 1–2 inches before braking begins, and rod adjustment is unlikely to help if the rod was not removed.
