right brake light is not working
1999 NISSAN MAXIMA
BSSUNIL
The right brake light is not working. I swapped the bulb with the left and the problem remains on the right side. So it is not the bulb. I am assuming fuse 15A (stop lamp) is common to both, so fuse must be ok. Checked for loose wiring, things seem ok. Any ideas?
Thanks,
-Sunil
Oct 10, 2015 at 7:21 PM
HMAC300
  • CERTIFIED EXPERT
  • 48,601 POSTS
check ground and check to see if power is going through wire if it is it may be a bad socket
Oct 11, 2015 at 8:25 AM
