First question. When it gets to 20-30 mph and revs up really loud, to me it sounds like the transmission is slipping when it goes to shift from 1st to second, by letting off of the gas the transmission shifts. Which would be why you can accelerate fine after that. My thought on this problem would be a transmission issue.
Second question. The pedal going to floor sometimes when you hit the brakes sounds to me like there is air in the brake lines, bleeding it out will probably solve the problem.
Third question. It sounds to me like the rotors are bad, depending on how long the car was driven on bad brakes, it could have wore groves in the rotors. If this is the case, the new pads you just put on will soon be bad again.
Hope this helps you out some. Feel free to come back if you have more questions!
SPONSORED LINKS
Friday, May 8th, 2015 AT 5:53 PM
