Replacing transmission due to reverse not working
105,200 MILES • 2.2L • 4 CYL • AUTOMATIC
LIL OZ
  • 8 POSTS
So I need to replace my transmission because the reverse won’t work. But when I went to a mechanic friend of mine he told me to just search for a 1/2 transmission kit or a reverse clutch so he can replace it. What exactly does that look like? And is it easier than just getting a newer transmission?
Feb 22, 2019 at 12:35 AM
KENW1
  • 213 POSTS
Thanks for visiting 2CarPros.
The half kit he's speaking of is one that has just gaskets and seals. It does not contain bands or clutch friction discs or steel plates. The kit and reverse clutch plate can be seen at the links below.
https://www.ebay.com/itm/Auto-Trans-Reverse-Clutch-Backing-Plate-ACDelco-GM-Original-Equipment-24200951/223360876693?fits=Model%3AL200%7CMake%3ASaturn&epid=75035772&hash=item3401588095:g:85IAAOSwSK1bJOSx:rk:4:pf:0
https://www.ebay.com/itm/Auto-Trans-Overhaul-Kit-PIONEER-750204/292661284730?fits=Model%3AL200%7CMake%3ASaturn&epid=112805530&hash=item4423f8cf7a:g:-gcAAOSwISNblq1H
As you can see you're looking at around $300.00 there. I don't recommend going into a transmission and not replacing friction material and bands. This kit is a little over $400.00
https://www.ebay.com/itm/4T40E-Master-Rebuild-Kit-4T45E-4T40-Transmission-Overhaul-Automatic-Transaxle-GM/382749927178?fits=Model%3AL200%7CMake%3ASaturn&hash=item591dac670a:g:NksAAOSwD~Fb1LID
Unless your friend has rebuilt a few of these specific transmissions, I would advise going with a one from a salvage vehicle that had low miles. There are some on eBay for under $400.00 and you could also search at car-part.com
Feb 22, 2019 at 3:34 PM
