Resetting body control module
1995 OLDSMOBILE AURORA
94,000 MILES • 4.0L • V8 • 2WD • AUTOMATIC
ECSTERLING
I went to reprogram the key fobs and forgot to put the key in the ignition before using the jumper wire to connect #4 and #8 in the Data Line Connector do when I did, the interior lights started blinking and now nothing works right. The key fobs, the gauges, the door locks etc., don't work and the defroster comes on high fan and full hot when starting the car but the climate control cluster is not on so no way to adjust it. What do I do to get it back to normal?
Feb 1, 2021 at 1:35 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is a tutorial showing how to reset a key fob. Try this first.
https://www.2carpros.com/articles/how-to-re-program-a-key-remote-fob
Let us know if this helps. Thanks for using 2CarPros.
Feb 1, 2021 at 3:30 PM
