Welcome to 2CarPros.
Here are the steps that I believe should work on a 1990:
_____________________
Turn the ignition key to the run position (engine off)
Within 5 seconds, press the accelerator to the floor 3 times.
Wait approximately 5 seconds and turn the key off.
___________________
Let me know if that works. If not, I will look further into the reset process, but that should do it.
Aug 24, 2019 at 12:56 PM
