Replacing HLA adjuster?
2011 HYUNDAI I20
15 MILES • 1.2L • 4 CYL • 2WD • MANUAL
L TIATOM
  • 61 POSTS
Is it possible to remove and replace all the 16 HLA adjusters for this vehicle listed above without removing the timing cover?
Because my thought is that after removing the rocker cover, we can see the bolts resting along the camshafts, and the upper timing guide too.
So, by removing all the bolts, and then jiggling the cams to get itself loose, I hope all the HLAs can be removed. (Of course, I would make sure the timing chain is hooked at somewhere so that it does not drop into the timing cover)
I would really appreciate it if someone could throw lights on this.
Mar 4, 2023 at 5:43 AM
  • CERTIFIED EXPERT
  • 53,872 POSTS
Can you upload some images of what you are trying to accomplish? we need to see what you are talking about to help.
Mar 5, 2023 at 4:42 PM
