Replacement tail lights
1991 GEO PRIZM
108,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
ODH
I need to replace tail light on my car listed above it is a Sedan. Since this is basically a rebranded Toyota Corolla, will the tail light assembly for a 1991 Toyota Corolla mount on my Geo Prizm as a replacement? Any help will be appreciated.
Dec 3, 2018 at 10:48 PM
  • 110,236 POSTS
Honestly, that is something you will have to try to see if they will work. There is a good chance they will, but doing it is the only way to confirm. Some of the time they will make small changes that make them incompatible, try getting one from a salvage yard that has return policy if it wont fit
I can tell you I looked up part numbers and they are different. So, whether that is because of the brand name difference or a design difference, I cannot tell without having them in front of me.
Dec 4, 2018 at 9:10 AM
