Replaced solenoid pack and car won't move
2003 JEEP LIBERTY
163,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
ROXBOROUGH1
I have a 2003 Jeep Liberty 3.7 with a 42rle transmission. After getting code p1776 and going into limp mode I replaced my solenoid pack. After I had everything put back together I had trouble starting the jeep. I had to move the gear shifter up and down while turning the key. After it was started and in drive I couldn't move and the engine revs. I didn't have these symptoms before replacing the solenoid pack so I'm guessing I did something wrong. Any ideas? Thank you!
Sep 5, 2015 at 11:43 PM
HMAC300
  • CERTIFIED EXPERT
  • 48,601 POSTS
recheck your work make sure the trans has fluid an d connections are correct at trans so neutral is lined up with switch where it's supposed to be.
Sep 6, 2015 at 7:55 AM
