1996 Toyota Camry Airbag Light On
The next concern is the fault code did not say to replace a part. They never do. Fault codes only indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition. This code refers to an open circuit in the "squib", or "initiator" circuit. That is the circuit that goes to the rocket fuel pellet in the air bag. Given that new parts are involved, a good suspect is a connector terminal got bent over or pushed out. Parts for safety systems go through a real lot of testing on the assembly line, so it is very unlikely the new clock spring is defective. It is also unlikely the controller developed a problem just at the time you were working on the system. Double-check the part number and application. Be sure the same number of terminals are in each connector, then check closely for bent or spread terminals.
My only personal experience with failing to erase fault codes was on a mid 1990's Dakota ABS system. The codes could be read by ground a wire, then watching the flashing of the warning light, but it could not be erased except with the factory scanner. They only did that for one year. The aftermarket scanners never gained that ability because it pertained to such a low number of vehicles that used that rather basic system.
The reason for requiring a factory scanner to erase codes is they are in a safety system, and the manufacturer wants to be sure any problems were repaired properly and nothing was bypassed. They are doing that for liability reasons since so many people sue for anything today.
Happy to hear it is solved. I am adding your solution to my memory banks.
Suggested Repair
Verify the clock spring part number and inspect every airbag connector for bent, spread, or pushed-out terminals. If code 14 remains with a good circuit, clear the airbag memory using the specified diagnostic-connector grounding sequence or a capable factory tool, since a standard scanner may not erase it.
Conversation Summary
A 1996 Toyota Camry developed a persistent airbag light and code 14 after combination-switch and clock-spring replacement, although the horn and cruise control worked. The expert explained that the code indicates an open squib circuit and may have been set while a connector was unplugged; it does not automatically mean the new clock spring is defective. After connectors were checked and a normal scan reset failed, the owner used the documented AB and Tc grounding sequence. The light then completed its self-test and stayed off.
