Code P0015, how to replace sensor
144,000 MILES
LEROYHORTON
P0015 code . Need to know how to replace the sensor and it's location on vehicle.
Jun 22, 2020 at 1:02 PM
Good morning,
The code is for the exhaust cam timing retarded. This could be from a timing chain or dirt in the solenoid. The most common is dirt in the solenoid not allowing the timing to change.
I would have the oil system pressure flushed with a cleaning agent. This is not an oil change or additive added. It is a procedure that flushes the system of all dirt and debris.
I would start by having a shop perform this service to start.
Below is a description of the code and how it sets.
There is no simple part to replace for this issue.
MONITOR DESCRIPTION
1 The ECM optimizes the exhaust valve timing using the VVT (Variable Valve Timing) system to control the exhaust camshaft. The VVT system includes the ECM, the Oil Control Valve (OCV) and the VVT controller.
2 The ECM sends a target duty-cycle control signal to the OCV. This control signal regulates the oil pressure supplied to the VVT controller. The VVT controller can advance or retard the exhaust camshaft.
If the difference between the target and actual exhaust valve timing is large, and changes in actual exhaust valve timing are small, the ECM interprets this as the VVT controller stuck malfunction and sets a DTC.
Example:
A DTC is set when the following conditions Procedure A, B and C are met:
(1) The difference between the target and actual exhaust valve timing is more than 5°CA (Crankshaft Angle) and the condition continues for more than 4.5 seconds (Procedure
(2) It takes 5 seconds or more to change the valve timing by 5°CA (Procedure "B")
(3) After above conditions procedure A and B are met, the OCV is forcibly activated 63 times or more (Procedure "C")
3 DTCs P0014 and P0024 (Advanced Cam Timing) are subject to 2 trip detection logic.
4 DTCs P0015 and P0025 (Retarded Cam Timing) are subject to 1 trip detection logic.
These DTCs indicate that the VVT controller cannot operate properly due to OCV malfunctions or the presence of foreign objects in the OCV.
5 The monitor will not run unless the following conditions are met:
1 The engine is warm (the engine coolant temperature is 75°C [167°F] or more).
2 The vehicle has been driven at more than 40 mph (64 km/h) for 3 minutes.
3 The engine has idled for 3 minutes (retarded angle side only).
Jun 22, 2020 at 10:19 PM
