1987 Renault Trafic New clutch
1987 RENAULT TRAFIC
48,000 MILES • 4 CYL • 2WD • MANUAL
PHILL185
I have just put a new clutch in my 1987 trafic camper, and it is difficult to get gears, I have adjusted the clutch cable correctly and replaced the gearbox oil with 3.5 ltrs of EP80 oil, any ideas on the problem I have would be greatfully welcomed.
Mar 7, 2009 at 9:04 PM
DAVE H
  • 13,384 POSTS
If you are absolutely sure you have the cable adjusted correctly .. I would be double checking you have the gear linkages lined up correctly for the selectors to engage correctly ... hope this helps ..let me know
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_99.png
Mar 8, 2009 at 1:14 PM
