2002 Renault Scenic FAILING TO START AND BATTERY LOSSING PO
2002 RENAULT SCENIC
28,000 MILES • 4 CYL • 2WD • MANUAL
POCCO
i have cheked conections to bothe power and earth cleaned all terminals and replaced the battery. i have checked the voltage of the altornator output and it is fine 13.8 volts when this happens it is when the car is at normal running temp. however this does not happen all the time but i do get a warning as the car seams to kangeroo slightly down the road as if it is running out of fuel please help if possible
thanks from tom
Oct 18, 2009 at 6:07 AM
