2000 Renault Scenic diagnostic code
ABING69
Transmission problem
2000 Renault Scenic Front Wheel Drive Automatic 82000 miles
hi i ve got a renault scenic with no forward gears but i have reverse have had a diagnostic test and have been given the code po 08706 it has cost me 70 pounds and he came bk to me saying it was the barrel in the gearbox had smashed up not sure if he was all that compitent and cant keep paying money out have not got it would really appreciate nay advice pls the scenic is a 1.6 16v
Sep 8, 2009 at 4:23 AM
DAVE H
  • 13,383 POSTS
The fault is definately inside the transmission .. you probably have worn forward gear clutch plates/rings or a bad solonoid switch inside the transmission .. it needs striiping down to discover the exact fault and repair ... it is possible to repair/recondition most transmissions/gearbox's .. on rare occassions there are metal parts inside which "smash up" .. a good transmission repair centre is your best option for repair !!
Sep 8, 2009 at 9:56 PM
