This can be quite a time consuming repair if you have never attemted before .. you have to remove the CV joint to replace the "gaitor" I'm not trying to put you off attempting this repair .. it is quite an easy procedure if you take your time !!... If I was you I would see if my local library had a repair manual to lend or purchase one from a local autoparts store .. these have step by step instruction's with diagrams for the repair !! hope this helps
SPONSORED LINKS
Tuesday, March 10th, 2009 AT 9:31 AM
