cam problem
RENAULT
KYLE H
i have a '99 (t) renault megane coupe 1.6 16v. recently the cambelt snapped and bent some valves, i had the head reconditioned and fitted with new valves.
i got a "friend" who is a "mechanic" to do the job for me as i did not know what i was doing, he refitted everything and for some reason the car would not fire. he assured me the timing was right however, due to the noise the car was making i did not think it was right.
to cut a long story short it turns out that he has installed one of the camshafts 180 degrees out, despite using the timing tool he got from his place of work.
i am just wandering if it is possible this has damaged any valves again or will we jus be able to re-time the cams and hope for the bet?
thanx in advance
May 14, 2007 at 9:14 AM
DAVE H
  • CERTIFIED EXPERT
  • 13,384 POSTS
the valves are damaged again i'm afraid ... they need replacing
Mar 20, 2009 at 9:10 AM
