1995 Other Renault Models Horn
1995 RENAULT
O_LUCHO
Electrical problem
1995 Other Renault Models 6 cyl Two Wheel Drive Manual
my car failed MOT on the horn. There is no sound. How can i fix this. i dont even know where the horn is under the bonnet?
Oct 30, 2008 at 11:12 PM
DAVE H
  • 13,383 POSTS
Without knowing the exact model I can't tell you exactly where the horn is located .. but they are usually located between radiator and front grill .. it is probably just a dirt/rust issue on the electrical connections to the horn ... remove wires .. clean up connections .. use multi meter to check your getting voltage .. if no voltage check and replace fuse if necesary .. reconect horn wires and test .. beep beep
Nov 8, 2008 at 4:35 AM
