My car is showing a lot higher temperature on dashboard than real one is. Fan is working correctly, level of water is OK. I have measured the temperature by laser and it shows 95 (+-2)C on thermostat or engine block, but on the dashboard scale is almost in "red".
I have also measured the temperature in driving by the laptop, and it didn't go over 97C (going uphill)- the scale was in very high (red) position again.
The charge voltage on battery is about 14.1V
Do you have any idea what should I do?
SPONSORED LINKS
Tuesday, October 21st, 2008 AT 6:56 PM
