2002 Renault Masters
735,000 MILES • 4 CYL • FWD • MANUAL
NOLANDE
My injectors not getting current
Jun 22, 2009 at 12:06 PM
DAVE H
  • 13,383 POSTS
The immoboliser cuts fuel injector function .. you need to check this is working correctly ... is the light flahing fast on the dash display ?
Jun 23, 2009 at 9:47 PM
NOLANDE
The light is flashing fast on the dash display
Jun 24, 2009 at 7:31 AM
DAVE H
  • 13,383 POSTS
Your vehicle is immobolised by the alarm/immoboliser system, the car's PCM (computer) is not reading the chip in the key and they need to be rematched together !!... use a spare key if you have one to try and reset it .. or you will have to have the vehicle plugged into a renault diagnostic computer (or equivalent) to reset the immoboliser system to start the vehicle !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_800.png
Jun 24, 2009 at 10:38 AM
REYREY5317
The engine immobiliser light goes out after a few seconds when the key is turned whilst i wait for the glow plug light to go out but the light that symbolizes an engine with stop written in it stays on with the serv light on but with my megane car those two lights go out when the key is in the m position but not on the van. I cant see why the immobiliser would be the problem as it worked fine before and has been unstarted for 4 weeks. i hope this additional information can help you to help me solve this thanks
Aug 18, 2009 at 1:50 AM
