2002 Renault Laguna safe mode
55,000 MILES • 4 CYL • 2WD • MANUAL
BILLY1BUS
my laguna 2 will suddenly loose throttle control the revs go up to just above 2000 and the electrical fault warning light comes on when it has been turned off for a while it returns to normal until the next time revs also pulse when it is in this mode
Jun 4, 2009 at 6:55 AM
DAVE H
  • 13,383 POSTS
you need to repair the fault that the code scanner is giving you, not just turn off the MIL to reset the computer ... repair the fault/sensor and the fault will not reappear on the cars computer and it will not go back into limp home mode !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_764.png
Jun 4, 2009 at 10:44 PM
