2002 Renault Clio engine service light
2002 RENAULT CLIO
SURESH1955
Engine Mechanical problem
2002 Renault Clio 4 cyl 62000 miles
How can you switch the engine service light off?
Apr 2, 2009 at 9:33 AM
  • 31,937 POSTS
Hi there,
If this is the check engine light you first need to scan the system to identify the fault that has caused the light to come on, do this and report the code for further assistance, if you just clear the code It will re set next start up.
Mark (mhpautos)
Apr 2, 2009 at 9:36 AM
