Removing driver's side front half shaft
2001 BUICK CENTURY
80,000 MILES
SCRAMERS6
I got everything loosened and only had the half shaft attached into the transmission. I tried to get it lose by pulling on the loose end of the half shaft. However, the half shaft came apart. I can send a picture if you provide an email address to send it to. I tried to use a wonder bar and smack it with a hammer, but it will not "pop" out of the transmission. Can you please, please provide directions and or photographs on how to remove it?
Aug 7, 2013 at 12:48 PM
SATURNTECH9
  • 30,869 POSTS
Can you use a long pry bar or extension and use it and hammer to tap the shaft from the back side is there enough room?They also make a slide hammer attachments one is fork that goes behind the axle.The other is a shackle clamp style that clamps to the axle joint.
Aug 7, 2013 at 3:18 PM
