Ignition will not turn all the way
240,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
BIG TREV
The key will go into the ignition but will not turn all the way. The lights in the car and the radio will come on but it will not turn enough to turn the car on. The steering wheel moves freely from left to right and will not lock while this is happening, but will lock when the key has no problems. It feels like there is something inside the ignition that has fallen and will not allow the key to turn. I have used both mechanic key and the vehicle key and they have the same result. I am able to get it started but it takes a lot to get the key to turn. What could the problem be?
Dec 24, 2017 at 4:36 PM
SATURNTECH9
  • 30,868 POSTS
The steering lock housing fail on those if the ignition cylinder moves like it should then all you need is the steering lock housing. If the ignition cylinder did not move like it should then you would need both the ignition cylinder and the steering lock housing.
Dec 26, 2017 at 2:38 AM
