Red lightening bolt light
187,491 MILES • 4 CYL • AUTOMATIC
JONATHAN MOSS
The car had no issues before I replaced my fuel pump last night. Then this morning I go to start the car and I get a electronic throttle body light and the check engine light come on. Then when I try to start the car it’s not starting like it was before the replacement, and the car now has like a muffled puffing sound coming from the exhaust.
Mar 10, 2020 at 11:38 AM
Good morning,
Why did you replace the fuel pump?
What is the code that is set for the check engine light?
https://www.2carpros.com/articles/check-engine-light-top-ten-reasons
You need a spark, fuel pressure, and compression to start. Have you checked any of these systems?
Mar 10, 2020 at 7:52 PM
