Red light security indicator
135,000 MILES • 3 CYL • 2WD • AUTOMATIC
TOM ZAMANIS
The red light security indicator stays on and the car wont start whatsoever. I recent replaced the battery so the battery should be fine and also replaced the alternator.
Oct 13, 2019 at 4:58 AM
AL514
  • 5,692 POSTS
Hello thanks for using 2CarPros. The security system may need to be reset due to the battery replacement. Here's a guide to help: https://www.2carpros.com/articles/how-to-reset-a-security-system
Oct 13, 2019 at 5:25 AM
TOM ZAMANIS
Hey, so I did what the article told me to do and now the red light is off, however the speedometer and tachometer are just clicking now consistently? The car still wont start and even with the key out of the ignition it still clicks.
Oct 13, 2019 at 6:46 AM
AL514
  • 5,692 POSTS
They're clicking? Do you mean jumping up and down or just a clicking noise coming from the instrument cluster?
Oct 13, 2019 at 7:03 AM
TOM ZAMANIS
They're all clicking and raising just a little, like every two seconds.
Oct 13, 2019 at 8:10 AM
AL514
  • 5,692 POSTS
I would have to say at this point, the body control module needs to be scanned to see if theres any codes stored. With the key out there shouldn't be any activity going on. Does the car even crank over?
Oct 14, 2019 at 2:45 AM
AL514
  • 5,692 POSTS
After a little research, make sure the battery terminals are extremely clean and connected tight. A bad ground can cause this issue too. Go through and find as many ground connections you can, including under the dash and engine compartment and make sure there's no corrosion or poor connections. These vans seem to have this issue quite a bit. Can you take a picture of the battery connections for me and post it here please? A lose connection behind the instrument cluster may be adding to the problem as well. Check all the fuses as well, under dash and in engine compartment.
Oct 14, 2019 at 2:56 AM
AL514
  • 5,692 POSTS
Okay, found something interesting. there seems to be a recall on the TIPM. (Total integrated power module). Check this out: http://www.chryslerproblems.com/tipm/
Oct 14, 2019 at 3:17 AM
