I replaced the ignition switch car won't turn on now so I got a code to re-coded but I don't know how to re-code.
Mar 26, 2020 at 7:28 AM
✓Experienced Mechanic
I wish I had an easy answer for you that could be done at home, but this requires software to do . Take a look at this:
The WIN initialization procedure is required whenever the WIN or shaft lock module is replaced on vehicles equipped with the shaft lock module. (wireless ignition node)
