I tried recharging my A/C a few times and it went straight into the red?
140,000 MILES • 2.4L • 4 CYL
CHRIS7979
I tried recharging my A/C a few times and it went straight into the red on the gauge. So, I took to mechanic, and they said I didn’t have any leeks and all I needed was a recharge, so I tried to recharge again, and the Freon started spewing out of the valve?
Jul 10, 2022 at 7:31 AM
  • 110,248 POSTS
What are you using to recharge the system? Are you certain you are attached to the low side?
Do me a favor. Take a look through this link and let me know if this is how you are recharging the system:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
If that is what you are doing, we need to get a manifold gauge set and check what the pressures are on both the high and low sides.
I suspect they vacuumed the system to determine if there were no leaks. It can hold a vacuum, but there can be issues with the compressor or something could be blocked. Take a look through this link to see how manifold gauges are used in a vacuum/recharge.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
If you have a gauge that goes into the red, be careful. Excessive pressure can cause the can to fail.
Jul 10, 2022 at 2:33 PM
