Rear struts
1991 CHEVROLET ASTRO
160,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
TAEKMIKE
  • 7 POSTS
I had the rear struts replaced ,but on the bottom of strut where the two bolts go there was a rubber insert by them and the person who replaced struts left them out due to him having a problem realigning the two bolts. The car seems to be fine now but was wondering what the rubber inserts were for and is this going to cause a problem later by being left out? I have the rubber inserts. Thank you
Aug 3, 2016 at 9:21 PM
HMAC300
  • CERTIFIED EXPERT
  • 48,601 POSTS
It needs an alignment otherwise you will get tire wear.
Aug 4, 2016 at 5:44 AM
