Rear light
14,000 MILES • 1.2L • 2WD • MANUAL
HAYLEY GOULDING
I have recently replaced a rear light on a mk8 Fiesta. The brake and indicator works but the normal rear light does not.
What could be causing this?
Regards,
Hayley
Nov 21, 2018 at 2:41 AM
BMDOUBLE
  • 1,139 POSTS
Your exterior lights are controlled by a body control module that has fet circuits for the lights, so if you have a bulb shorted or open the circuit will be disabled until it is repaired. I usually disconnect the battery to reset things and they usually work after that. If problem persists you will need to take it to the dealer or a shop that has diagnostic equipment that can read BCM codes. Hope this helps.
Nov 21, 2018 at 3:50 AM
