Rear brake rotor removal
240,000 MILES • 3.0L • 6 CYL • RWD
KEVNLKING
  • 26 POSTS
How do i remove the rear brake rotor. I already removed the brakes/caliper and the axle nut. I don't know if something else is holding. I see a screw that requires an axle wrench but I don't know what size it is. Its located behind the rear hub
Feb 12, 2016 at 3:44 AM
CARADIODOC
  • 34,406 POSTS
Look for two holes near the center hole, directly across from each other. You run a pair of metric bolts into them, and as you tighten them, they will push the rotor off the hub. There's no other way to get them off without damaging them.
Feb 12, 2016 at 4:01 AM
