Rear bed gate panel?
200,000 MILES • 4.6L • V8 • 2WD • MANUAL
ADDISON MADDISON
These early El Caminos had a very flimsy rear panel, unreinforced. The inner panel is ~ 4-6" inside of the outer panel. In the process of restoring mine - which is around 98% complete - I'd like to know if there is a way to make the rear outer panel less susceptible to denting in (even putting your hands on it wrong when closing it can cause it). It's just 60-year-old sheet metal. It's never been in a rear-end impact of any sort.
So, is there some sort of product (like a spray foam that will adhere and "rubberize") that I can use to make the outer panel more dent-resistant?
May 9, 2023 at 10:22 AM
  • 55,746 POSTS
Yes, this is a pretty good product we have used in the shop with good results.
https://amzn.to/3NY0CWs
May 10, 2023 at 4:39 AM
