Rattle under my hyundai coupe se
116,000 MILES
JOHN79851115
Hello
I'm looking for advice concerning my hyundai coupe se I've had this car for just under a year and its fantastic my only problem is there is a horrible rattle near the back left wheel arch and no one seems to have a idea what it is one garage said it could be the airel but after inspecting that's not the problem any advice would be a massive help
John
Jun 18, 2013 at 4:41 AM
CARADIODOC
  • 34,413 POSTS
There is a tool you might be able to borrow or rent from an auto parts store that borrows them called the "Chassis Ear". It is a set of six microphones, a switch box, and headphones. You clip the microphones to suspect points, then drive around while listening with the headphones. You can move the microphones around to zero in on the source of the noise. Be aware that many mechanics have never seen or even heard of this tool. Suspension and alignment mechanics use it to find rattles, squeaks, and other noises.
Jun 18, 2013 at 5:12 PM
JOHN79851115
Thank you for your answer I have heard of this before so will defo look into do you have any idea what could be the problem is the airel possibly causing the issue
Thanks
Jun 18, 2013 at 9:14 PM
