Range Rover P38 - 2000 - Rough engine run
2000 LAND ROVER
160,000 MILES
PETROST
Changed the camshaft, tapets, push rods, chain (OEM), spark plugs, coils, cables at 140.000 miles, cleaned injectors and just recenty the rocket arms as it had a clicking noise when idle (when hot only, it traffic or after driving in highway). Noise is still there. In Lynx tester shows no missfires but engine rough in cylinders 3 - 4 - 5 - 6. NO water leak. Recently cleaned MAF with MAF cleaner and become even more rough the idle.
Any suggestion what to look for.
Thank you
Jan 6, 2016 at 10:27 PM
HMAC300
  • CERTIFIED EXPERT
  • 48,601 POSTS
have a pro do a freeze frame to see if any other sensor is out of whack and check fuel pressure with a gauge auto parts rent it . also check for a vacuum leak.
Jan 7, 2016 at 6:20 AM
