randomly shuts off
250,000 MILES
GREEN6977
  • 25 POSTS
i have a 2002 f350 7.3 turbo in it and u can drive it for about a hour and it will just shut off. wait 45 to hour and it will start up just fine. starts fine first thing in the morning. i scanned he truck and i got ,0237,1209,1316,1212,0340,1211 if gave me all six of these code . and where is the cam position sensor located
Apr 16, 2013 at 12:41 AM
clear all the codes and drive it to see what code returns first.
have the high pressure oil pump and sensor checked.
Apr 16, 2013 at 9:54 AM
GREEN6977
  • 25 POSTS
how do you check those, i found a bunch of trast in the fuel filter bowl; i cleaned it and replaced fuel pressure regulator. also replace cam postion sensor. thanks for the advise
Apr 24, 2013 at 4:32 AM
you need a scan tool to monitor the high pressure. you need 800 lbs to fire the injectors
Apr 24, 2013 at 9:26 AM
