Random misfire on all cylinders
1997 ISUZU TROOPER
189,000 MILES • 3.2L • V6 • 4WD • AUTOMATIC
ROBERT SOLIS
Check engine light on, check codes got po300. did tuneup,replaced fuel filter, now light blinks, car kind of surges and light stays on. what could be the cause,how do i fix it?
Aug 19, 2017 at 11:44 AM
ROBERT SOLIS
Thanks, looking forward for a solution.
Aug 19, 2017 at 1:05 PM
HARRY P
  • 2,292 POSTS
When you did the tune-up, did you use OEM parts, or something else? I always suggest using original equipment when it comes to ignition systems. This is because a slight difference in spark strength can make a world of difference.
Aug 19, 2017 at 1:10 PM
ROBERT SOLIS
i used the recommended parts sold at auto parts, same plugs.
Aug 19, 2017 at 10:28 PM
HARRY P
  • 2,292 POSTS
At 189,000 miles, with new plugs and wires in it, I might suspect that you are having problems either with a bad/weak coil or old injectors getting clogged up. There is a school of thought that says that cheap gasoline with a high ethanol content (maybe 20% ethanol) will eventually gum up the injectors. I am not 100% sold on it though.
So the next thing I would look into is checking the coils. Here is a guide that will help you get started there: https://www.2carpros.com/articles/how-to-test-an-ignition-system. I know yours is not exactly like this one, but I get the feeling that you have a good enough understanding to apply the article to what you know. Also, you will need a multi-meter to check resistance. Resistance should be less than 10 megohms.
If you cannot check it that way, you can get a spark tester from Autozone or Amazon and check the sparks at the cylinders. You will be looking for a miss at somerpm range. A miss could be absolutely no fire for a second or so, or just a weaker looking spark. Here is the spark tester that I have: https://www.amazon.com/Lisle-20610-Inline-Spark-Tester/dp/B0002STSC6/ref=sr_1_3?ie=UTF8&qid=1501325755&sr=8-3&keywords=spark+tester
So try that and let us know.
Aug 20, 2017 at 11:55 AM
ROBERT SOLIS
thank you sir but i got it fixed,it was the oxygen sensor on bank 2 sensor 1,your help is appreciated
Aug 22, 2017 at 10:45 AM
HARRY P
  • 2,292 POSTS
Ahhh good. That'll do it, but it's not the most obvious fix. FYI don't be surprised if the other one goes soon. Generally, when one O2 sensor goes, the other side goes within a few months, because they have the same age on them. I always order mine from Amazon or RockAuto and save about $20 over AutoZone/Advance Auto.
Aug 22, 2017 at 1:05 PM
