Ran out of fuel, how to prime fuel?
236,000 MILES • 2.5L • 4WD • AUTOMATIC
RBZ
Hey guys!
The vehicle listed above is a d40.
Tried priming fuel after ran out of diesel... not sure if I'm doing it right as it still won't start.
After running out of fuel, I filled up, drove about 50km, then it lost power. Got a jump start drove home, now when I jump start, it starts up... (revs fluctuate), but then dies as soon as I disconnect the leads. Sounds like a battery problem... does that happen when you run out of fuel or is that just a coincidence?
Any advice from your experts about the best way to get started again would be legendary!
May 4, 2023 at 3:29 PM
BORIS K
  • 836 POSTS
A 50km run is certainly enough to fully prime the fuel supply system.
I believe it is a coincidence that the alternator is not charging
How to test:
https://www.2carpros.com/articles/how-to-check-a-car-alternator]
Also check the battery connections:
Cheers, Boris
May 4, 2023 at 7:44 PM
RBZ
Hi Boris, you were spot on! It was pure coincidence that the alternator was the culprit and not a fuel priming issue. Love your work bud, really appreciate you sharing your knowledge here, saved me a lot of time and headaches big time. Great website 2carpros! Highly recommend. Legend Boris, all the best.
May 5, 2023 at 12:15 AM
BORIS K
  • 836 POSTS
Thank you for the great feedback, really appreciated.
Spread the word, we are always happy to help.
Cheers, Boris
May 5, 2023 at 2:22 AM
  • 55,658 POSTS
BORIS K is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
May 5, 2023 at 4:57 AM
