question about fuel injector nozzels
1,000 MILES • 4 CYL • 4WD • MANUAL
88YODAPICKUP
I've got an 88 Toyota pickup and I bought new injectors for it but 2 of them have a slightly different nozzle, it's a tiny bit longer and slimmer and the two holes that spray fuel are much larger than the other ones, which match the original ones I took off. My question is do the hole size matter? Is it going to spray more fuel into the cylinders than the other 2 or is the pressure regulated so they all spray the same amount?
Mar 14, 2016 at 9:17 PM
HMAC300
  • 48,601 POSTS
They have to be correct otherwise they will spray too much fuel. They go by how many pounds of fuel they spray
Mar 14, 2016 at 10:54 PM
RENEE L
  • 1,260 POSTS
Thank you for visiting 2CarPros. Please let us know the answer was helpful to you.
Mar 17, 2016 at 10:28 AM
