put litle power steering in brake reservor
139,000 MILES
PHILCAT39
  • 7 POSTS
Hi i mistaking put about one half oz power steering fluid in my brake resvoir, I used a turkey baster to suck empty twice and put in new brake fuild both times, is this enough to handle or should i bleed whole system?
Jan 8, 2016 at 6:21 AM
HMAC300
  • 48,601 POSTS
it should be ok if you never applied the brakes. if your pedal feels spongy at all then bleed them
Jan 8, 2016 at 7:10 AM
PHILCAT39
  • 7 POSTS
well did go down street to neighors and back used brakes 2 or 3 times lightly, brakes feel ok so should I still bleed, I hear brake fluid doesnt circulate much is that true?
Jan 8, 2016 at 7:44 AM
HMAC300
  • 48,601 POSTS
you should be ok, brake fluid doesn't circulate a lot only when the pads wear down will it enter the rest of system.
Jan 8, 2016 at 8:32 AM
