Put in a new transmission and still leaking in the front
1995 CHEVROLET SUBURBAN
164,000 MILES
PAMELA7564
Thought it was the front seal because it was over full by a half quart so pull it back out and replaced it still leaking only when running in park and when you frist shut it off makes a puddle about the size of a quarter
Jun 27, 2013 at 7:33 AM
SEANGRANT00
  • EXPERT
  • 334 POSTS
Check the cooler lines that run on the side of the trans for any cracks or loose connection to the the trans. Is the leak coming from the converter case or somewhere else?
Jun 27, 2013 at 12:18 PM
PAMELA7564
Coming from the weep hole
Jun 27, 2013 at 1:38 PM
SEANGRANT00
  • EXPERT
  • 334 POSTS
Sounds like the pump bushing is spinning or walking from the body. You may have to replace the bushing, it requires a press though.
Jun 27, 2013 at 2:46 PM
