Programming pass-key
279,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
CHARLIESCOTT
How do I program a passkey without a garage?
Nov 17, 2018 at 3:47 AM
  • 110,246 POSTS
There are two ways to do it. One requires a scanner and the other does not. However, it takes thirty minutes to do without the scanner. Here are the directions without the scanner:
___________________________-
30-Minute Relearn Procedure
Use this procedure after replacing the following components:
- The passkey III (PK3) keys
- The theft deterrent control module
- The PCM, see important above
IMPORTANT: This procedure is not available on vehicles equipped with option code (Z49 or BAE).
If replacing a theft deterrent control module with an GM SPO Replacement Part, perform the procedure to setup a new theft deterrent control module prior to the 30-minute relearn procedure.
1. With a master passkey III key (Black), turn ON the ignition, with the engine OFF.
2. Observe the Security telltale, after approximately 10 minutes the telltale will turn off.
3. Turn OFF the ignition, and wait 5 seconds.
4. Repeat steps 1-3 two more times for a total of 3 cycles or 30 minutes.
IMPORTANT: The vehicle learns the key transponder information and/or passwords on the ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
5. With a master passkey III key, start the vehicle. The vehicle has now learned the key transponder information and the PCM has now learned the fuel continue password.
6. With a scan tool, clear any DTCs.
Nov 17, 2018 at 10:23 AM
CHARLIESCOTT
I have done that over twenty times and the security light does not turn off. Car turns over for a second but will not start.
Nov 17, 2018 at 6:53 PM
CHARLIESCOTT
And my key does not say passkey 3 it is a B97-PT.
Nov 17, 2018 at 7:32 PM
CHARLIESCOTT
It is not working.
Nov 17, 2018 at 10:56 PM
