Problems with the ac/heater
2005 FORD
255,034 MILES • 2WD • AUTOMATIC
CFOLLOWILL22
Whenever I turn my AC or heater on it makes my car cut out and start to shake. Do you know what could be wrong with it?
May 30, 2017 at 7:15 AM
STEVE W.
  • 15,419 POSTS
Could be a bad AC compressor if it does it when the AC or defrost is on. It is also possible that there is a shorted wire on the electrical side that draws enough current that the voltage drops. The AC compressor could be tested easier, just unplug the connector that turns the clutch on. If the issue stops it's a bad compressor.
Without knowing what the actual model and engine is that is about all I can tell you. Please give that information and we can try a few other tests.
May 30, 2017 at 9:19 PM
CFOLLOWILL22
I am going to see if I can find that information and I will let you know.
May 31, 2017 at 6:45 AM
  • 55,770 POSTS
Here is a guide on how to replace the compressor
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Jun 3, 2017 at 5:05 AM
