Will not go over 3,000 RPM's or 70 mph and speedometer does not work
204,000 MILES • 3.2L • V6 • 2WD • MANUAL
AJSLENDER
I bought this car about a month ago. The speedometer doesn't work, won't go over 3,000 revs or 70 mph. It has a 5 speed in it. Trying to figure out if it's a bad ECM or BCM.
Oct 9, 2020 at 12:15 AM
  • 110,248 POSTS
The idea that the speedo doesn't work indicates an issue with a speed sensor. That can affect the transmission functions. As far as what is causing the problem, it could be several different things.
The first thing I recommend is to have the computer scanned for diagnostic trouble codes. The best way to do it is via a CAN scan. CAN stands for computer area network. This is how the modules/computers in the vehicle are tied together.
Once the codes are retrieved, we then can focus on a specific area. If that isn't done and we have no codes, it becomes a guessing game.
Here is a video that shows how to scan the CAN bus system of a vehicle:
https://youtu.be/InIlnsjOVFA
Once you have that done, let me know what codes are retrieved.
If this is something you are unable to have done, let me know. Also, let me know if you have other questions.
Oct 9, 2020 at 12:18 PM
