Premium fuel versus regular fuel
105,000 MILES • 6 CYL • AUTOMATIC
JUNIOR1964
  • 36 POSTS
Hi, i would like to know what happens if i added a regular fuel instead premium fuel?
Feb 12, 2019 at 4:53 AM
  • 110,248 POSTS
Audi recommends the higher octane fuel for a couple reasons. First and most importantly, it is more refined. As a result, it is less likely to leave deposits in the fuel system and allows smoother performance from the engine design. Concern areas include, but are not limited to, valves, injectors, fuel pump and so on.
Next, the engine compression plays a role in this. Lower grade fuel can allow for valve knock or damage. If the car is turbo charged, I strongly using what they recommend. I own two of them and always spend the extra 5 bucks per tank to fill-up.
Feb 12, 2019 at 10:08 AM
