Power to Injectors
48,870 MILES • 1.6L • 4 CYL • 2WD • MANUAL
SAMTETTEH1
Can leaking injectors causing the car to smoke and also do over-float when starting? I replaced these injectors but the car starts and stops in two to to five seconds without smoke. I test the battery power to the injectors and it is okay. But I tested the power from the ECM to the injector when the leaking injectors are on the engine, and I found no power at all. I see the ECM is okay, but there is no negative power after the car starts. I suspect the problem to be coming from the crankshaft/camshaft position sensor. Where can I locate it?
Nov 9, 2018 at 1:58 PM
  • 55,542 POSTS
Did you use OEM fuel injectors? If you use aftermarket injectors the resistance can be off causing the problems. We do not have information on this car for the crankshaft sensor location, but the last one I saw is up at the crankshaft by the timing belt.
Nov 12, 2018 at 3:00 AM
