If it's leaking from the power steering pump, will it be able to turn easily?
Nov 27, 2022 at 10:42 AM
✓Experienced Mechanic
If you have a leak, the degree of the leak will determine how difficult the steering wheel will be to turn.
How bad is the leak? Is it spraying out indicating it is a pressure line? If it is the return line, it shouldn't affect the steering until the fluid gets too low.
