Power steering pressure sensor location
300,000 MILES • AUTOMATIC
TMZ
We cannot find where the power steering pressure sensor is located. There must be one, right? Unless there is something else, some other mechanism, that is responsible for kicking the RPM's up when you are turning the wheel at idle. The power steering pressure sensor is mentioned in the Chilton repair handbook we have, but there are no images, or diagrams of it, and it says it should be located on the steering gear but there is nothing on the steering gear. This book covers multiple years and is not specific to the 2003 Astro, though. We have worked on this vehicle for fifteen years and basically know every inch of it, but this has us stumped. Have taken everything apart, followed the power steering lines from the pump to the steering gear and brake power booster and back to the reservoir and cannot find anything that looks like a sensor. Do you know where we can find it? We are 95% certain that is what the problem is based on researching the symptoms, and it seems like it should be replaced if we can find it. Of course, it is possible we are barking up the wrong tree.
Nov 9, 2018 at 3:37 PM
SATURNTECH9
  • 30,869 POSTS
I am going to have to say it does not have one. I just looked at the high pressure power steering line and there is not a place for one. That is where it would be if there was one. What problem are you having?
Nov 9, 2018 at 4:05 PM
TMZ
While turning into a parking spot or stopped at a stop light it idles rough. It feels like the entire vehicle is shaking. It does not do this when driving at high speed down the highway, it feels fine.
Nov 9, 2018 at 4:21 PM
SATURNTECH9
  • 30,869 POSTS
So is the engine rooms bouncing around or your just getting vibration? You could just have some bad engine/transmission mount issues.
Nov 10, 2018 at 1:34 AM
  • 55,710 POSTS
Yes, a power steering pressure switch will not cause this. I would service the throttle body. Here is a guide:
Let me know what happens.
Nov 10, 2018 at 7:54 AM
TMZ
Saturntech99. the engine and transmission mounts have all been replaced.
Ken, that could be it, but it is going to be a time consuming job. We will let you know how it turns out if we do it.
Thanks for your help guys!
Nov 10, 2018 at 6:22 PM
  • 55,710 POSTS
It only take about twenty minutes to do the job which I highly recommend. I think it will fix the problem.
Nov 12, 2018 at 1:50 AM
TMZ
Thanks Ken, it will take us a lot longer than that. ;)
Nov 12, 2018 at 8:05 AM
  • 55,710 POSTS
Let us know. :)
Nov 13, 2018 at 2:39 AM
