Power steering leak
77,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
BONZI13
  • 11 POSTS
Need to know how to tell if I need to replace power steering pump or power steering high pressure hose.
All power steering fluid came out of area located behind the driver front wheel. It was not a drip type leak. It came out fast when I started the SUV. Smelled of burnt oil and looked like dirty brownish liquid kind of a semi thick consistency. I am thinking the seals in the power steering high pressure hose seals may have blown out, but I do not know how to tell exactly where the problem is.
Jan 22, 2018 at 12:02 AM
SATURNTECH9
  • 30,869 POSTS
It sounds like the high pressure line is leaking from the description of the leak. But without looking at the area it is hard to say. Try refilling it and start it up and see if you can see where it is coming from. Just be careful that is high pressure.
Jan 22, 2018 at 12:03 PM
BONZI13
  • 11 POSTS
A week ago I posted a question about a power steering fluid leak. However, I forgot to include more information about the symptoms.when I was driving I heard a whining noise and saw a lot of power steering fluid (brownish in color smelled like old burnt oil) under my car on the ground. I refilled the resistor with power steering fluid and was able to get car home at that time (with no whining or grinding noises). With the prior information I gave you a week ago I was advised it may be a power steering high pressure hose. i am wondering if it may be a steering rack problem instead. How can I tell the difference? my car is in my driveway and has not been driven since i got it home.
Jan 29, 2018 at 8:02 AM (Merged)
CARADIODOC
  • 34,415 POSTS
You have to crawl underneath and look for the leak. If the entire area is wet and the leak is rather slow, you may need to wash the area first with engine degreaser, then rinse it with water, and dry it. Start the engine, then you might need to have a helper slowly turn the steering wheel back and forth. You do not have to turn it far or fast. It simply needs to be moving for the pump to start putting pressurized fluid in the hose.
The location of the puddle on the ground is a good starting point, but be aware, due to the nature of how rack and pinion assemblies are bolted in, fluid can run along and inside the front cross member and drip out at an entirely different area.
The first thing to look at is the high-pressure hose. Once washed and dried, the two common places to look are the metal tubes crimped to the ends, and for a split along the hose. Watch for fluid oozing out and running down the hose.
The next, more common suspect is the steering gear itself. Typically a rack seal will leak fluid into one of the flexible accordion boots around an inner tie rod end. There is an air transfer pipe slid into and connecting the two boots. Fluid will flow through that pipe into the second boot. It can take up to about two quarts of fluid to fill those boots, then the fluid will get pushed out the small end on one or both sides.
When there is an obvious loss of fluid, but with no puddle or wet area, suspect the rack seal is leaking, but the boots have not filled up yet. To identify that, slide off one of the hose clamps on the small end of one of the boots, then use a small pick with a right-angle hook on the end to pull that boot open a little. If fluid comes running out, the rack must be replaced.
When the leak is too slow to wait for while watching underneath, consider adding a small bottle of dark purple dye to the power steering fluid. Search after driving a few minutes, an hour, or a day, as appropriate, with a black light. The dye will show up as a bright yellow stain that you can follow back to the source. This is not real effective with fast leaks because the entire area will be wet, and glowing yellow.
Auto parts stores will have the bottles of dye for the fluid being tested, and those that rent or borrow tools should have a black light.
BONZI13
  • 11 POSTS
Understood. Thank you. Appreciate the info will follow you're instructions.
Jan 30, 2018 at 12:38 AM
STEVE W.
  • 15,418 POSTS
Be careful when looking for leaks. Power steering fluid is under high pressure and a small pinhole leak can act like an injection needle and inject power steering fluid right into your body.
Jan 30, 2018 at 1:31 PM
BONZI13
  • 11 POSTS
Understood. Update it was high pressure line. Friend checked got new line installed it. Working fine. Thanks again!
Feb 22, 2018 at 1:34 PM
STEVE W.
  • 15,418 POSTS
Good to hear you got it repaired. Thank you for using 2CarPros. Please return anytime with your automotive questions.
Feb 23, 2018 at 1:52 AM
