Power steering hose.
41,000 MILES • 1.6L • 4 CYL • AUTOMATIC
KEEGANJDAVIS
  • 10 POSTS
I'm replacing my power steering pump, the pump has two hoses attached to it, one is a simply clamp which I got off, the other has a bolt of some kind holding it down. Do I need a power tool to remove this, or can I do it by hand?
Apr 14, 2016 at 2:33 AM
JIS001
  • 3,412 POSTS
You should be able to remove by hand. Also make sure to replace the washers. If you are replacing the pump for noise, inspect the reservoir screen for debris. If you cant see the screen or you see debris in there, replace the reservoir as well.
Apr 14, 2016 at 4:02 AM
